OK, so we have some MCC's that are HRC3.  There are some buckets that need to be shut down for maintenance fairly regularly.  The question is, has anyone seen a mechanism for verifying a Lockout outside of the bucket door?  It would be so much safer and efficient to perform a verification this way.
I do not believe the "Voltage Indicators" that are out there are valid for this application since there is no practical way to test the indicators after you shut off the power (test the tester - test for voltage - test the tester).
An initial thought was to install test points on the bucket door with a cover and label identifying them as verification test points.
Anybody want to play Devil's Advocate?
If this has come up in the past, please direct me to the appropriate thread.
Thanks...
Thanks...
