I personally see no problem with using tie wire to support MC cable.
The NEC does not specifically permit or prohibit the use of tie wire, it is really up to the AHJ to approve the securing and supporting means for MC cable.
The problem I hear said is when the tie wire is too tight cutting into the MC
Thats funny, I really did not read Chris's post before making mine.![]()
On a case of tie wire I received the outside of the box said something like used normally for tie down of steel rod
Why do I bother posting, nobody bothers reading them anyways.
Chris
As others have said there is no requirement that the supports for MC be listed and there is a specific permission to use cable ties.in the same respect what about tywraps we have been getting shot down on using them because most of what we get are not ul listed.
330.30 Securing and Supporting.
(A) General. Type MC cable shall be supported and secured by staples, cable ties, straps, hangers, or similar fittings or other approved means designed and installed so as not to damage the cable.
On a case of tie wire I received the outside of the box said something like used normally for tie down of steel rod.
Just to say I am not against using tie wire it is on how you installed it like other products.
