Hi,
I'm using ETAP to model underground raceways. I am having trouble modeling my situation because of certain geometric limitations with the Neher-Mcgrath method. I want to model DC cables in conduit buried below 4" of concerete. The concrete would be flush with the surface of the earth. The analysis software is telling me that the raceway is too close to the surface. How else am I supposed to model this situation? Is there some variation on this method I can use, or can I add some variance factor to make it work out? I'm thinking I might just have to model a "worst-case scenario" and go with it but I was wondering if anyone else has run into this problem.
Thank you for your time,
Andrew
Andrew
