jasondienethal
New member
How can a GFCI work with nonmetalic plumbing? I have a GFCI outlet that will trip from phase to ground, but it will not trip if i go from the faucet to groung, or the metal sink to ground. The supply pipes are metal, bu the riser from the valve to the faucet is PVC, as are the drains. Will the GFCI work properly if you drop the apliance in a sink full of water?
