A Alwayslearningelec Senior Member Location NJ Occupation Estimator Aug 12, 2010 #1 I tried to google this. What is a multi tap light. Does it mean you can run either 120/208 or 277/480 to it? Thanks.
N nakulak Senior Member Aug 12, 2010 #2 multi tap ballasts accept different ranges of voltages. You need to see the spec for the ballast, it will tell you what voltages it accepts.
A Alwayslearningelec Senior Member Location NJ Occupation Estimator Aug 12, 2010 #3 nakulak said: multi tap ballasts accept different ranges of voltages. You need to see the spec for the ballast, it will tell you what voltages it accepts. Click to expand... Got it, thanks a lot.
