Chain type PVC Saw
Use masons string line
I have had good luck by using simple mason's stringline or nylon sting. I cut apiece off and use screwdrivers or such for handles and saw away. Perfect for cutting pipe in a ditch.
Never seen a chain, but a wire one is commonly found in plumbing departments in any hardware/big box DIY store.
There is one with a chain, but it is in the lawn and garden dept.
The string works BUT, some strings don't work, and if it is a 4" have the sawzall or hack saw ready, so you can just cut the top half if need be.
That mason line works some times like butter other times it binds up and breaks every other stroke:mad:
But I have broken the rope-saw too:roll:
