Installing receptacles in the base cabinet for gas range and a Jenn air 240V grill top.
I?m thinking of using a carlon zip box for the Gas range off a general circuit in the kitchen not the appliance circuits. Can I go though the lower cabinet with this zip box and put a face plate on it and be done with it. Or would a metal box with an extender be better?
As for the Jenn Air 240 grill top. I?m thinking a 4x4 box with an extender that would also go though the lower cabinet, and put plate on for the whip on the 240V grill.
Does this sound ok?
I looked at the Carlon Zip 4x4 Range boxes; ( has sticker on the side that states range) I never used these boxes. I guess you drill though this then clamp? I don?t see how a face plate can go on this box. So metal 4x4 with an extender appears the way go on this to get though base cabinet.
This customer wants the carlon boxes, Im not sure what damage can be done to carlon box in the base cabinet. That?s if the cabinet guys screw up. I like metal for this reason
I have not done residential work for a couple of years, so I have not seen many new products for this type install.
Does this sound ok?
