First, some info:
I have encountered a 50kva, single phase, 480v primary, 120/240 secondary, dry type, indoor transformer. All the voltages to/from the unit are correct. Currently, the unit is loaded to 29 amps, on the secondary.
The top, external casing of the unit is so hot to the touch, you can not keep your hand on it for more than a few seconds. With a IR temp gun, I read 162 F degrees on the top of the unit. The manufacturer has stated to me that the unit "skins" or casing can have a temp of up to 194 F degrees (90 C). I can not imagine that this is correct (and I have asked for this in writting), since a temp that high could burn someone on contact.
The unit was factory tested and came with a cert from the factory (saying it was tested by them, and all was OK) :-?
Now the questions:
What would cause the unit to run this hot, bad windings???? Contaminents in the core steel?????
I could not find anything in the code or white book. Any ideas????
Now the questions:
