SPC522
- monmouth county,nj
home owner is having his bathroom remodeled...the jacuzzi tub requires two 15a circuits one for motor one for heater.. i ran two homeruns from panel to a 2 gang box in bathroom which i placed two faceless gfci's in and from there to under tub.. under the tub i used a 1 gang nail on and a duplex outlet which i just split to accomidate two circuits.. also ran a #8 bond from panel and bondeed motor heater and both water supply lines... basically the question is are there any code violations involved here? the inspector is very picky and i havent done a jucuzzi in years and for some reason im second guessing myself about using the split outlet...
thnx
figure the only dumb question is the one you dont ask
thnx
