brother
I was having a conversation with this guy and we were having a discussion about some of the codes not being for the trained worker. This is based off the 2008 NEC, so far it seems to be more and more codes that are for the 'untrained' or 'unfamiliar/unqualified' worker that is 'messing with this stuff' than it has to do with true general safety of the public and property are being made. You can ADD to this list if you wish!!
210.4 MULTIWIRE BRANCH CIRCUITS (B) DISCONNECT MEANS. Even though I don't really care for the shared neutrals, This code section is basically for those that are not familar with or not trained with shared neutrals and how to work with them. A 'trained' person can handle them just fine. No need for the common disconnect.
90.4 ENFORCEMENT. I know Im gonna get in trouble for this one
, and Im sure some inspectors apply/use it properly, but tooo many times I hear from some EC's claiming that they just make up 'code' as they go. This code article is basically a 'BECAUSE I SAID SO' enforcement, an inspector does'nt have to give another code section to reject something he just doesn't like, or even be trained or familiar with.
110.15 HIGH LEG MARKING. You have to identify the high leg of a delta by the color 'orange' or other means. The only reason someone would hook up the high leg to a 120 motor or other circuit/receptacle' without knowing it is because they didnt check the VOLTAGE. One should always test the voltage, circuit before hooking the equipment to it.
As I said, untrained or unfamiliar with the work.
Thats all I can come up with off the top of my head, I will be back!!
