Is there anything wrong with running several 12/2 NM cables thru a 16 ft. PVC sleeve? I know it's OK to sleeve one cable (e.g. down a basement concrete wall). But is there a problem with running several cables in one sleeve as long as I comply with conduit fill limitations? Because of the outer jacket of NM cable, could there be extra heat trapped in the long PVC sleeve when there are other NM cables bundled in there as well? Thanks for any help with this.
