issue one . the outlet 6' to 20' away has an obvious purpose although a{6} explains the measurement is effected by floor wall and so on or other effective permanent barrier.
is this a dense row of bushes a knee wall or 8' fence for privacy and sound .
inspector one says follow the path the cord follows and measure that way.
inspector 2 says follow strait path even over 8' fence as long as path is less then 20' if some one uses extension cord to go around not my problem
issue two a deck box about 15' from the pool 10" above surface. possibly argued in walk way to motor and controls should this be protected with 4" *4" post or a bush. or take the point of view it is not in the walk way around the immediate pool area
your point of view would be appreciated
