jetlag
- Eatonton, Georgia
My first thought was the air tight cans would be much better because would keep the room and attic air from mixing, but then I started thinking maybe in summer you would want the heat from the lamp to go out but then on the other hand when the light if off the hot attic air will enter the house. Also in winter the ic would have to be better for keeping the heat inside. I still believe the air tight is the best , any comments.
