I helped a friend of mine locate an Arc Fault problem last night.
Arc fault to the Master Bed and Bath tripped and shut off all of the lights.
When I got there I tried to reset the breaker but it would trip immediately.
I took the hot and the neutral off and the breaker held.
I left it on, and touched the neutral to the breaker neutral terminal and it tripped.
I thought that it was interesting that it tripped even though the hot was not hooked up,so I reset the breaker but left the hot disconnected.
went down the line seperating the neutrals in the switch boxes until it cleared.
Found a socket in the Vanity Light where the neutral was touching the metal housing, repaired it and it solved the problem.
I dont do residential work but I just found it interesting that I could troubleshoot the problem without ever having to connect the hot to the breaker.
