I know it is possible to serve multiple motors from one VFD however I have an application where I have two motors of identical horsepower however one will be a standby in case motor 1 fails, they are also deigned to alternate hours to provide each motor with equal run time. Typically when two motors are connected to a single drive both will operate at the same speed (correct me if I am wrong) would it be possible to serve both motors from a single VFD sized for one-motor and thru a BMS signal and a contactor supplied with the motor circuit protector (one for each motor) alternate the motors and arrange it so if one were to fail the other would start? Would there be any disadvantages to this arrangement? thanks.
