Flex
 - poestenkill ny
Ordered copper range cable from the supply house the other day and got #8. My boss says it needs to be #6. Im not sure either way. What information do I need to know to see who is correct here?
Is that how you ask for it?Ordered copper range cable from the supply house the other day . . .
Does the range need a 50 amp breaker. Most standard ranges use a 40 amp breaker.
8/3 copper NM with a 40 amp breaker has become the standard.
#8 copper or #6 aluminum SE on a 50 used to be the standard.
Do you mean #8 Cu NM cable? When did that used to be a standard?
