Capacitor sizing?
Ken9876
Jersey Shore
How would you correctly size a capacitor for a DC power supply? I was building a 12vdc power supply at work the other day and wanted to know how to get the right size and not just throw caps in the circuit till it worked right.
100831-2045 EST
Larry:
Why?
What is the % ripple, output voltage, frequency, and configuration of the rectifier for your 1000 to 2000 mfd?
If there is a fixed output filter capacitance and the load resistance is constant, then the % ripple remains constant independent of the output voltage. The output current is proportional to the voltage.
If output current is held constant while output voltage is varied and C is constant, then % ripple voltage changes. Constant current with a change of voltage means the load resistance is changed.
% ripple voltage is determined by frequency, rectifier configuration, and the RC time constant.
Thus, output voltage, allowed % ripple voltage, current, frequency, and rectifier configuration must be defined to determine the value of capacitance.
X microfarads per amp is not sufficient.
The size of the capacitor can be determined by a bit of maths, but the first important questions for a standard mains powered power supply followed by a full wave bridge is what is the current that will be drawn from the 12V supply, and then what ripple you are prepared to accept.
It may be that a simple capacitor filter isn't adequate for the ripple you will accept..
