Need expert opinions....please!
I finished wiring a pool today that has four 12v LED lights fed from a 300 watt Intermatic 120/12V transformer. The tansformer is being fed with a 15 amp GFCI breaker. The 120v is being broken by a single pole switch 60 feet away from the transformer.
The setup works as it should but if someone cuts the switch on and off in rapid succession (four or five times) the GFCI breaker kicks out. I know this is not the normal way to use the switch but the family has kids and it is possible for this to happen.
My question is "Is it normal for a GFCI breaker to kick out from in-rush current from a transformer when the power is cycled rapidly." and if is normal "Is there a way to fix the problem?"
Thanks for any help you guys can provide.
