Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I encountered a strange situation with a 3 way switch. A receptacle was located near a three way switch. The two wires from the receptacle were connected to the two travelers on the nearby switch. Somehow this worked. The problem arose when I replaced a small junction box in the basement.
Once I had reconnected everything the receptacle only worked when the light controlled by the three way switches was on. When off, the receptacle would not function, HOWEVER; on checking the receptacle I found that the neutral was switched--not the hot.
I correct the problem by rewiring the receptacle to a different circuit. Any idea how this was originally wired?
