Will Wire
- California: NEC 2020
- Electrical Contractor
I?m working on a house that was built in the late 1950s or early 1960s. The house was built with circuits without equipment grounds. A subpanel was installed in the garage. The neutral buss of the subpanel is isolated from the enclosure and there is no ground bar. Over the years people have installed new circuits and have connected the equipment grounds to the neutral buss. A couple of years ago the main service entrance equipment was upgraded and the existing subpanel was fed with a four wire feed and both the ground and the neutral wires were attached to the neutral buss bar. Is this unsafe? Why? My understanding has been that the neutrals and grounds are connected to the neutral buss at the main service and no where else unless the panel is located in a separate building. Thank you for your attention to this matter, Trent
