Photometric software
We are a design/build contractor and are having issues with turn around time on photometrics from a 3rd party. Can anyone recomend a program that will work with CADlite 2007? I have a small program that uses the .IES files but only shows a small detail. I want to be able put layer on a cad plan. Any ideas?
I was giving a program buy my lighting supplier to use. It was made by Lithonia. You may want to check with them.
I replied to you earlier post about photometric software...
Try "Visual" by Acuity Brands Lighting
http://www.visual-3d.com/
The software is free, but you will need to contact a vendor for a serial number.
I have used this software for years as a consulting engineer. This is not the best or most powerful program, but works for most applications.
You can import an ACAD plan, plug in any IES files either through downloading specific manufacturers files, or using files that come with the software.
Software comes pre-loaded with all Lithonia fixture IES files.
