ivsenroute
- Florida
The panel is existing, the HVAC ductwork is new. There is nothing in the mechanical code against this and if there is not any electrical work or electrical permits for this job, how can this be addressed?
IMO, The HVAC guy needs to move the duct...
IMO, The panel needs to be moved, electricians have to eat to.
And look at it. it's a mess.![]()
IMO, The panel needs to be moved, electricians have to eat to.![]()
Of course !what was I thinking.:-?..
That might not be easy choice but is the right call. Sometimes you simply can't run duct any other way. If they lower the panel and install ceiling over area could they pass the 6 foot 6 inch rule ?I am both the electrical and mechanical inspector.
The job was failed and he was given 2 choices:
1) Move the panel
2) Move the duct
Yes but i sure don't like itCould you legally install a ceiling that low?
They opted to move the duct. There was plenty or room on the other side of the basement and this was simply poor planning on the HVAC end.
That was what I was thinking, unless that panel cover is sitting on something, that panel can't be more then 36" to its bottom, its a HOM1200 30/40 which is about 30" high which is 66" to it's top, which to me says that duct is somewhere around 55" off the floor? but then the cover could just be sitting on something after all:grin:
Not a HOM panel, it's ITE or ITE/Siemens.(Depends on the age).![]()
1) Move the panel
2) Move the duct
Sounds good to me.
I never did understand why some people would think they need to only follow one specific code for any type of install.
You cannot violate other codes while following one code.
