eljefetaco
- Fanwood, NJ
Don't think this is the best way to install a hot tub outdoors, but I think it meets code. Hot tub is 50a, 240v requires GFCI protection. 1. Install 60amp 240v gfci breaker at main panel. 2. Install 60amp fusable disconnect with 5' of Hot tub (will a pull out disconnect not work? i.e. one for AC) 3. Install 50amp fuses 4. Bond concrete pad to disconnect with solid #8. Just seems odd you can have disconnect within 5'. 680.41 is a safety switch tha same thing as a disconnect? It is for one home in a condo complex. I know that refers to non single family dwelling. Any input on my run sentences?
