Hello everyone;
I don't know about the means of 300.16 NEC.
Would you mind if explaining or illustrating by pictures ???
Tks and BRs
The "open and concealed" wiring of 300.16 is surface mounted cleats with individual insulated conductors clamped in the cleats (open wiring), and Knob & Tube (concealed wiring).I don't know about the means of 300.16 NEC.
monkey fist or birds eye, do you have any pic to illustrate ???
And "monkey face" is another name. Here are two older images I found. Above I was talking about BX armored cable, but these show a fitting that is made for use on NM cable. The difference is the BX monkey face will have a set screw to anchor on the BX armor, instead of the cable clamp shown below for the NM sheath.monkey fist or birds eye, do you have any pic to illustrate ???
