Ok, I'm fully aware this isnt code compliant, but we did it anyway. We had to install a series of convience outlest behind paintings in a museum. The outlet had to be super low profile to avoid touching valuable paintings. The outlets where for light fixtures that are attached to the painting frames....
Here's what we did as per the owners instruction....
On a solid masonry wall, we drilled a 2 1/2" diameter hole with a core bit 2'' deep. Over the hole we installed a shallow 3/4'' Wire Mold extension
box. In the Wire Mold extension box we installed a clock recept that is recessed. We used #14 awg stranded and crimp spades and protected the circuits with 15 amp breakers. The only connection we had in these boxes was a single yellow wire nut that pigtailed the ground tails fastened to the back plate of the extension box and the clock recept. We tucked the single wire nut in the corner of the extension box.
We did approx 50 of these installations and it worked very well for the application. Im fully aware that it doesnt meet code, nor is it UL listing compliant, but it does meet the intent of the code IMO as there is no way it can catch on fire.
Ok, I've got my bullet proof vest on now, fire away....
