Does anyone have any advice as to the best way to size a portable generator for a residence? I just need to know what is the best size portable generator to cover critical loads in a particular residence.
The loads are well pump, furnace, fridge, outlet for computer modem, a couple of lights and living room outlets.
The problem is that I don't have any precise specs on the well pump and furnace. The best guess on the well pump (which is 120 volts) from very general documentation off the web is about 13 amps; and the furnace tag says "less than 12 amps." Do I need to take actual readings when they cycle on? Or can I just multiply amps x volts? Do I need to use a multiplier for start up current -- if so, what is it?
And is there a formula to calculate lights and receptacles?
Sorry that my questions are so basic -- this is the first time I've had to actually recommend a particular size of generator.
Many thanks for any help.
