Taking ohm readings at a sub panel and found a range circuit with .2 ohms neutral to egc. In the range there is a strap between the neutral and egc.
Should this strap have been removed on installation of a 4 wire tail?
The idea behind a 4 wire install was so that the neutral and egc could be separated. Most ranges come with the strap jumping the two however, it needs to be taken off.Taking ohm readings at a sub panel and found a range circuit with .2 ohms neutral to egc. In the range there is a strap between the neutral and egc.
Yes, the strap is for the exception in 250.140 for existing 3 wire installs.
Jumper,
Any idea which code cycle had this exception was inserted ?
Jumper,
Nope, where is Ken/480sparky.
Yes should been removed but likely was pigtailed by appliance man or owner. Now the real question is can you red tag the job as this is a plug in appliance ?
