Pad mount transformer - Filter Press
qms006
Not sure where to post this question, so I'll try it here. I'm going through our specs on pad mounted oil filled transformers and came across the term filter press connection.
Does anyone here know if the filter press is actually on the transformer oil compartment itself or is just a connection to connect an external pump and filter?
My understanding is it is the connection point for a filter press system, which is an external filtration rig with a pump and high-pressure fed filter (commonly called a filter press.) There is no filter press in the transformer AFAIK.
