jbgoosehunter
Trying to run 2 277 Volt 1000 Watt HID Floods on one leg of a 3 ph 480 Volt 100 Amp fused disconnect which is running 2 30 Amp 3 ph AC units. When I tap into one leg of the power it zero's out my voltage on the leg im trying to use and raises the voltage on the other 2 legs. Wondering if it is just throwing it out of balance? What to do? Should I try and run the 2 fixtures from 2 different legs to help balance the load?
