In an apartment building with 16 units that are being rehabbed due to a fire caused by a tipped-over candle, a 1/2 inch continuous plastic sprinkler pipe runs horizontonally 30 inches above the unit's 100 amp panel. Both panel and sprinkler pipe are installed inside the same stud run. All wiring enters the bottom of the panel.
Is there a danger with this? Should it pass inspection?
Thanks
Thanks
