I would say, technically, the LED is an outlet.
Technically, you're nuts. :grin:
Unfortunately you are also right but I can't imagine someone hitting on that-- cept Ken.![]()
.................bob would have, but he's elsewhere trying to boost his post count.![]()
I would say instead that the presence of the LED is what turns the outlet box into an outlet. The LED itself is just a load. Indeed, if I were to try to be technical, I would say that the point at which the wires (having entered the box from the conduit) are screwed onto the GFCI/LED device is the "outlet." :roll:I would say, technically, the LED is an outlet.
Agreed. But I would be willing to grant that stretch, before I grant the notion that the switch itself comprises an "outlet."I think it is a real stretch to say that the LED indicator is "utilization equipment".
So a switch is not an outlet, but a lighted switch is?
It fits the NEC definition of an outlet.
I agree with 480.
You will get more of that than you bargain for, if you stay around here too long.Believe it or not, I appreciate the excruciating exactness of critical thinking.
