Ok, I am gonna say this again slowly since no one seems to be listening:
FPE panel.
Evidently everytime the OP gets near it the problem clears for a while.
FOP ain't gonna find this one.
FPE panel.
FPE panels and breakers have a history of bad bus connections.
OP needs to carefully pull ALL the breakers, (pull the meter if there is no main, and/or if there is a main because you'll need to inspect the main to bus contacts as well.)
FPE panel.
Inspect each and every bus stab point, especially if they are the style attached to the bus with screws.
FPE panel.
Tighten any that are loose and/or replace the panel if any show signs of overheating or arcing.
FPE panel.
Do you customer a favor and suggest a replacement panel before the thing goes up in flames.
Hopefully this time my message registers. If not, here's a helpful visual aid courtesy of another forum:
			FPE panel.
FPE panel.
FPE panel.
FPE panel.
FPE panel.
