Diconnect on Heat Pump / Furnace
chadvz
New member
Does an electric furnace inside the house need to have a service switch wired to it if you have to unscrew the furnace panel to kill the breakers inside. There are breakers in the panel located in the garage and breakers located inside the furnace box. Does the nec require a service switch to turn off the power.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician, then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
