Minimum voltage the code defines
Typically in jurisdictions, we see voltage limitations based on licensing agreements.
In the NEC if you are concerned about voltages, check these references for informational purposes:
90.2, Art 100- Voltage (of a circuit)-nominal-to ground, 110.4, 110.30, 220.5 and other articles such as 411, 490, 720, 770, Chapter 8, etc...Generally the last PART of many Articles. These are not restrictive, but just relative to voltage ratings.
