I ran across this forum searching for anything related to this problem.  It seemed like the posters here had quite a bit of experience and may shed some light on a problem that we have.   I sincerely apologize in advance if this post is irrelevant or not appropriate for this forum.
We are a manufacturer of electronic audio equipment. We have an installation of our products in a foreign country where they have strapped our product to some light poles. I do not know what kind of light poles they are. I only know that they take 10-15 minutes to power up fully.
The light poles are mounted into a raised concrete floor, thus not actually into any earth.
The product mounted to the poles has its own separate 220VAC power with its own ground. It also has two other connections that loop to each other, a twisted pair shielded serial data connection that daisy chains to several products, and an audio twisted pair shielded wire daisy chained to several products.
When the lights are coming on, our products are being damaged by high voltages at the inputs of the data and audio connections.
I can only assume that there is induced voltage somewhere and a path from one pole to another via the data or audio connections is happening.
They have already tried using rubber isolators between the poles and the product's aluminum housing, and are not finding any large voltage potentials between the chassis ground and the light poles (during normal use). I don't know if they have also tested when the lights are powering on.
Any suggestions or a direction to look into would be most appreciated if you've ever heard of such issues.
