Yep! My town adopted the IPMC, & I'm the go to guy with it.If your juisdiction has adopted a Property Maintenance Code, the Inspector may be able to address it.
Did this come from the AHJ or the POCO? I'm not quite sure how it works but a POCO does not have to energize your equipment and here, they will not energize it with out a written release from me, so if they see something they don't like they will require that a permit is taken out for the repairs or replacement and an inspection is made.
I've also brought this up before, but an inspector cannot walk away without noting any violations that he sees. Now I agree that I don't have the right to poke around where ever I want, but if I'm there for a service change and there's an old outlet there missing a cover, I am well within my rights to write it up. Or if I have done my due diligence and checked the address file before I went out and one of the things hooked to the new panel is a nonpermited AC unit then again, I write it up.
One has to remember, the Property Maintenance Code generally is the only code document that can be retroactive in the enforcement process.
But..................
Private property owners have the right to privacy in this country. So, if an inspector is called to inspect a kitchen, it does not give him the right to walk around the rest of the house. If he does, the owner can actually sue for trespassing. I have seen it happen, and this wording is not in the Admin portion of the codes, but in the actual legal documentation of the State. I have the wording around here somewhere, maybe I will look for it.
If a homeowner does not want to let an inspector onto his property, he can decline the official access. The official would then have to go to a judge for a warrant. That official better have a good reason for the judge to write the warrant.
NO! Article 90 of the NEC is for introduction and is not enforceable.Does 90.4 cover the AHJ's ability to determine that existing electrical equipment must be replced or is another code article referenced to do so?
Personally i wish they had the right to inspect everything. Can you say plenty of OT
