I'm an electrical apprentice looking for alittle help with my schooling.
I predict 435 post on this.Question is Two voltages of 90 V each are out of phase by 120 degree's, what is their Vector Sum. thanks
This sounds suspiciously like a two phase problem with the angles and voltages swapped. Could we really mean 120V @ 0 and 120V @ -90?
I'm an electrical apprentice looking for alittle help with my schooling. Question is Two voltages of 90 V each are out of phase by 120 degree's, what is their Vector Sum. thanks
Even more unlikely because two phase power is dead-dead-dead.
thanks for the Help, i guess the math is not that easy for me. Anyway you could lay it out more.
To add vectors, start by drawing the two vectors so that the tail of the second vector is at the head of the first vector. You have to do this without changing the length or direction of the vectors. Just move the second vector so its tail is at the head of the first vector.
Now the vector sum is the vector drawn from the tail of the first vector to the head of the second vector. If you drawn it right, all three vectors will make a triangle.
Now that you have your vector sum drawn, you could measure its length and angle to get your answer. But that's not very accurate. You want to use trig. to mathmetically find the result.
