SPARKS40
- Northern Il
I have a buddy of mine who just bought a portable 5500 watt generator. He fired it up and was checking the voltage with my Fluke 117 that he had borrowed and was getting a reading of 130-133 volts on each leg with no load. Is this typical of the portables to emit a slightly higher voltage, or is there something wrong with the genny? I figured that under load it should be okay, but he's wanting to be able to run his furnace off it, as well as lights, fridge, chest freezer, A/C, etc. Should it be an issue for any electronics run off it, or should it be limited to the essentials, such as lights and refrigeration equipment? What should be the maximum acceptable voltage output?
