GG
 - Ft.Worth, T.X.
Does a hallway that is 4' or 40' get 1 smoke detector regardless of the length of the hallway? Someone is telling me that a "long" hallway gets 2 smoke detectors.
			Put smoke alarms at both ends of a bedroom hallway or large room if the hallway or room is more than 30'(9.1m) long
Just to clarify a 30' hall must have the smoke detector in the dead center. As stated the smokes generally have a 15' spread but you do need to check the specs as this is not a NEC issue.
You got it easy in Ma. In NC one in every bedroom and outside each bedroom hall area. We also need one on every floor whether there is a bedroom or not. If there are permanent stairs (not pull down) to an attic then one is required up there even if it isn't finished. of course they are all interconnected.
I'm always impressed how professional the attitude is here on this forum.
in massachusetts, you have to have a CO detector within 10 ft of a bedroom and a smoke outside of every bedroom, since we use combo smoke/co's - we sometimes use 2 in a long hallway especially because there usually are bedrooms at each end of the hallway. You also need a smoke at the top of the stairs - so do you need 3 in some cases? only in a large house - but we have done that before to satisfy the requirements - sounds kind of silly to have so many - but - last year a 6000 sq ft house we wired caught on fire in the middle of the night (it was not the wiring that caused the fire) the smokes went off and saved the family.
