OK, 210.52(f) states the minimum circuit required, but my question  is what code section applies since this isn't a laundry room inside a  residence. It is the common laundry area for multiple units. I plan to put each appliance on its own circuit, so that's not a problem. The question has to do with the load calculation for the feeder. I don't recall off the top of my head what the standard load is for a washer or a gas dryer, but lets just say it's 1,200 watts. I have 6 machines, which would be 7200 watts. The sub panel is only 120v so it would be 60 amps. (7200/60). Am I permitted to take 75% of the load due to the 6 appliances? Or does this not apply because it's nor treally in a residence?
