400 hz
domnic
Electrical Contractor
What is the advantage of useing 400 hz in airplanes and where else is it used?
400 hz
So what is the down side of 400 hz and wy dont we use it more?
Aviation
Aviation
The main reason, and the one that remains today, is that the "magnetics" are so much lighter. In aircraft design, we sweat gallons to reduce the nonpayload (non-paying) weight by a few pounds! For a given mission, if you increase the aircraft weight by a pound, you increase the required fuel by several pounds which means that you have a smaller payload unless you build a bigger aircraft which costs a lot more.
Larry
