Nothing I don't believe unless the building code requires some stop if it runs between floors. Article 820 I presume.When rigid conduit is used as a sleeve to run coax cable (for TV) what is required on the ends of the pipe? What article of NEC refers to it?
Plastic snap on bushings or if you dont have and just put a coupler. The idea is no sharp edges
