That's a lot in many instances.What is it a 1/2 " thinner?
Yep, even without the bushing.Is that a permitted method of landing MC?
Why not?Does not seem so.
Why not?
Maybe 314.17(B)
Where raceway or cable is installed
with metal boxes or conduit bodies, the raceway or
cable shall be secured to such boxes and conduit bodies.
it is secured to the box, with the clamp inside the box...
I did before.Oops! Did I just spot a clamp?
Nyah-nyah! :grin:You are correct. I did not see it the first time.
Especially if you're using the rear threaded KO.That half inch would really make a difference. There's a reason I only use deep bell boxes for GFCI's...
What's the reason they left the extra clamp in the box to possibly ground out the black conductor. :roll:
