- NE Nebraska
- EC
With no equipment ground what does a three light tester have for a reference to determine proper polarity between the hot and neutral?
I would verify polarity with a meter.
Does the satellite equipment have a grounding type plug? It may need one to bleed off static charges and without it you may have voltages between the dish and receiver via the cable - properly bonded cable to electrical system however, should still eliminate this.
