Bathroom receptacle circuits
Pitt123
I thought I saw somewhere once that a bathroom receptacle circuit can not serve any other loads such as lighting in the bathroom. Similar to the required branch circuit in a laundry room that cannot server any other loads including lighting.
Is this true for bathrooms as well.
In 210.11(C)(3) does each bathroom require a dedicated branch circuit or does this just say at a mimum one is required in a dwelling?
210.11(C)(3) and its exception give you a choice:
  • Supply anything you want within a single bathroom (receptacles, light, fan, whatever). But if you do this, then that circuit cannot supply anything outside that one bathroom.
  • Supply receptacles in two or more bathrooms from the same circuit. But if you do that, then this circuit cannot supply anything other than bathroom receptacles.
I don't know if they can afford me. What is the salary like? ;):D
Do you have an electrical device or invention whose use you would like to see made mandatory by the National Electrical Code?
Let's talk. lol :)
