Hot AC wire problem?
lviv.net
New member
On the wall between bedroom and bathroom, the stud-sensor shows that there is a hot AC wire, and the non-contact indicator shows the same. When I cut out the drywall, there aren't any wires. Can anybody help me understand what this is? What tools can show me?
How does a stud finder sense voltage? You probably are sensing some phantom voltage. Those non contact detectors are not reliable, IMO. Often you will get a signal that a wire is hot when it is , in fact, not energized.
There must be wires nearby-- what are you looking for? There are some tools that can trace wires underground and thru sheetrock but those cheap ones will not do it. Usually you need to spend a few hundred dollars.
Any HV transmission lines in the area of this house?
Had a house that was right next to the right of way of a 500kv transmission lines, and my non-contact sensor would go crazy getting close to anything metal like water pipes, also go out side and check for voltage between the water spigot and earth with a DVM, you might have a lost neutral problem and are picking up the water pipes?
