Technically you must follow the 2005 but some inspectors may accept a less restrictive code if shown that the nec changed their view on it. Problem is the inspectors may have to cover their butts.
Look at it this way-- if the NEC has a more restrictive change in the 2008 should they make you do the more restrictive code. Personally I think that if you are under the 2005 then that is what they will demand esp. since you don't know what your state will accept or amend when and if they accept the 2008 NEC.
Dennis, well stated.
If your caught going 55 in a 45 mph road and they change the sign a few days later to 55 did you speed ??? Think it will be up to the judge or in this case the inspector.
Jim
This is an analogy I like, and I believe the general electrical population can understand.
To the OP
This is a common question these days based on the fact so many jurisdictions are all over the place in regards to Code Cycle adoption.
The administrative codes of jurisdictions and 90.4, the last two paragraphs help an inspector to permit alternate installations based on the current codes.
Art 690, Photovoltaic installations are a consideration I believe that an inspector has to consider when dealing with PV. PV equipment and installations are generally very much linked to the current NEC cycle. So, when one is following the '05 NEC, the '08 is out, and the '11 is soon to be out, it puts an installer in a precarious position. The '05 code is based on information that is
5 YEARS old. It is difficult to install PV to this old standard. Talk to the AHJ, in NYC it is best to get it in writing from the Head Inspector.
