inspector 102
- Northern Indiana
Because I am only an inspector, I am having trouble with this issue. A ventilation fan was installed having a 5-amp rating. A variable speed controller was used also having a 5-amp rating. Apparently when the varible controller is set to a lower setting, the ventilation fan stops working. Since 5-amps translates to 550 watts, does it sound like the controller needs to be increased to a 1000 watt controller or is this the motor causing the issue. Because this is located at our local fire department and used for exhausting dust from the fire extinguisher work area, I am trying to assist them in figuring out which component is the cause, the controller or the motor. I believe that the 1000 W controller will solve the issue and allow the motor to operate at the lower speed because the resistance at slow speed is causing the controller currently to overheat and cut-out. Any comments appreciated.
