chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
I was asked to help out our best all around electrician today. I have great faith in this fellow's attention to detail so I found this call quite odd.
He installed two fans with light kits under a open porch ceiling. He then installed remotes with canopy receivers. One worked fine, the other never addresses/recognized the light kit. When he pulled the chain for the light kit the receiver smoked.
I was called after he went through two light kits, one whole fan and two remote kits. Bear in mind that the twin is functioning properly.
So I wire the fan directly to the branch circuit and fan motor works but light kit fails to come on. Take light kit apart and defeat the watt-limiter and it works fine. So at this point I have a perfectly functioning fan/light.
The electrician install another remote, which I read the entire installation instructions for and where followed to a T. Again during power up, during the learn mode the motor came on but the light kit was not recognized. Pull the chain and smoke. OK, take the receiver back out and all is well again.
Model numbers;
Fan: Fanimation FP4320
Remote kit: Fanimation CRL 4WH
My initial guess is that this home is located over an ancient Indian burial ground but i defer to you resi guys to see if you have experienced anything similar.
Thanks for reading a long post.
Model numbers;
