interchanging motor satrt capacitors
Can you substitute motor start capacitors with different uf/VAC combinations if you don't have an exact replacement?
On my outside AC compressor and fan, I did that to get them to start over a weekend. On Monday went and got the correct size. Voltage was a match though, just cap values were different.
If you are asking about a start capacitor (usually 70 mfd or higher) the voltage needs to be right but the mfd can be +/- 10 percent. If you are asking about a run capacitor( below 70 mfd) then the voltage can be higher but the mfd needs to be exact.
